NI TestStand
i need to knew were can i put a code that will run after any step.
i want that a specific code that i wrote will run after any step in the main sequence.
this code suppose to increment a variable if the step is failed.
i did not find the place in the VB Operator Interface that executed after each step.
please tell me where i need to put my code so it will be excuted after any step regardless if the tracing is enabled or disabled.
this question is about the original source code of TS VB Operator Interface.
advaced thank's.
avi gafa, RADA,Israel.
(4,107 Views)
Avi,
There is an NI KB article on this titled "How Can I Perform Some Action
After Every Step Executes" at:
http://zone.ni.com/devzone/devzoneweb.nsf/opendoc?openagent&06109F4BC56EAC03
86256838005EB865&cat=629CD2F2758A8D00862567C2005ACE42
HTH,
Bob Rafuse
Etec Inc.
"avi gafa" wrote in message
news:506500000008000000B7160000-984280909000@quiq.com...
> the main sequence.
> after each step.
> Interface.
> advaced thank's.
(4,107 Views)
the link is dead!
(4,107 Views)
> the link is dead!
Hmmmm.... I just was there yesterday. Did you append the URL stuff that
wrapped to the next line? Instead of clicking on the link in the message
cut and paste the two lines into your browser's address bar, concatenating
the two lines. That should do the trick.
Bob.
(4,107 Views)
I agree with Bob that I think you would be better to implement what you are wanting to do within your actual test sequence rather than modifying the VB operator interface code. You can easily do what you are wanting to do by using a SequenceFilePostStep callback in your test sequence file. As the document that Bob is referring to points out, this callback executes after EVERY step in your sequence file. The specific Developer Zone document that Bob is referring to can be found by going to Resource Library>>TestStand>>Sequence Execution>>Execution Flow>>How Can I Perform Some Action After Every Step Executes?
Richard McDonell
National Instruments Corp
www.ni.com/ask
(4,107 Views)
