NI TestStand
Passing Variables in TestStand through LabView
I have an error I am trying to set up an overwrite on the Database Options Callback. I am telling TestStand which database to write to. I am passing it a variable and I get an error. Below is a description of the error.
Here is the Statement I am using:
In the DatabaseOptions Callback I am using a statement to change which database the data is being stored.
I have a VI that passes a string which is the location of my database file I want to use. I have it stored as variable in StationGlobals called database (It is currently a String but I have tried executable and path also with the same error).
Parameters.DatabaseOptions.ConnectionString = StationGlobals.Database
StationGlobals.Database is set to
"\"Provider=Microsoft.Jet.OLEDB.4.0;Persist Security Info=False;Data Source=C:\\Users\\Public\\Documents\\\\National Instruments\\\\TestStand 4.2.1\\Components\\Models\\\\TestStand Results.mdb;\""
There has to be a problem with the variables because when I copy and paste what StationGlobals.Database in and use the following statement it works perfectly fine.
Parameters.DatabaseOptions.ConnectionString = "\"Provider=Microsoft.Jet.OLEDB.4.0;Persist Security Info=False;Data Source=C:\\Users\\Public\\Documents\\\\National Instruments\\\\TestStand 4.2.1\\Components\\Models\\\\TestStand Results.mdb;\""
The following is the error that I get:
Details:
An error occurred calling 'LogResults' in 'ITSDBLog' of 'zNI TestStand Database Logging'
An error occurred initializing a connection to a data link.
Connection String: "Provider=Microsoft.Jet.OLEDB.4.0;Persist Security Info=False;Data Source=C:\Users\Public\Documents\\National Instruments\\TestStand 4.2.1\Components\Models\\TestStand Results.mdb;"
Description: [Microsoft][ODBC Driver Manager] Data source name too long
Number: -2147467259
NativeError: 0
SQLState: IM010
Reported by: Microsoft OLE DB Provider for ODBC Drivers
Source: TSDBLog
Error Code:
-2147467259; User-defined error code.
Possible System Error: Unspecified error
Step 'Log Results to Database' of sequence 'Log To Database' in 'Database.seq'
Please Help I can't find any solution to this question.
Thank you very much for any help
(3,804 Views)
Accepted by JDASM
Once again, Expression Strings, has stumbled another programmer!
Parameters.DatabaseOptions.ConnectionString is not a string but an Expression String, and your assignment of a StationGlobals.Database ( just a string ) is causing this error.
Here is what I did to solve your issue:
1.) StationGlobals ( remove the leading "\" and trailing \"" from the Database string ) it should contain NO leading or trailing quotes
StationGlobals.Database = Provider=Microsoft.Jet.OLEDB.4.0;Persist Security Info=False;Data Source=C:\\Users\\Public\\Documents\\National Instruments\\TestStand 4.2.1\\Components\\Models\\TestStand Results.mdb.
2.) In Database Options Callback use the following expression to set the Data Source
Parameters.DatabaseOptions.ConnectionString= "StationGlobals.Database"
There are other alternatives as documented in this link.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YILKCA4&l=en-US
Good luck,
PH
(3,794 Views)
Thank you so much that was very helpful
It worked perfectly
(3,788 Views)
