NI TestStand
Passing Variables in TestStand through LabView
I have an error I am trying to set up an overwrite on the Database Options Callback. I am telling TestStand which database to write to. I am passing it a variable and I get an error. Below is a description of the error.
Here is the Statement I am using:
In the DatabaseOptions Callback I am using a statement to change which database the data is being stored.
I have a VI that passes a string which is the location of my database file I want to use. I have it stored as variable in StationGlobals called database (It is currently a String but I have tried executable and path also with the same error).
Parameters.DatabaseOptions.ConnectionString = StationGlobals.Database
StationGlobals.Database is set to
"\"Provider=Microsoft.Jet.OLEDB.4.0;Persist Security Info=False;Data Source=C:\\Users\\Public\\Documents\\\\National Instruments\\\\TestStand 4.2.1\\Components\\Models\\\\TestStand Results.mdb;\""
There has to be a problem with the variables because when I copy and paste what StationGlobals.Database in and use the following statement it works perfectly fine.
Parameters.DatabaseOptions.ConnectionString = "\"Provider=Microsoft.Jet.OLEDB.4.0;Persist Security Info=False;Data Source=C:\\Users\\Public\\Documents\\\\National Instruments\\\\TestStand 4.2.1\\Components\\Models\\\\TestStand Results.mdb;\""
The following is the error that I get:
Details:
An error occurred calling 'LogResults' in 'ITSDBLog' of 'zNI TestStand Database Logging'
An error occurred initializing a connection to a data link.
Connection String: "Provider=Microsoft.Jet.OLEDB.4.0;Persist Security Info=False;Data Source=C:\Users\Public\Documents\\National Instruments\\TestStand 4.2.1\Components\Models\\TestStand Results.mdb;"
Description: [Microsoft][ODBC Driver Manager] Data source name too long
Number: -2147467259
NativeError: 0
SQLState: IM010
Reported by: Microsoft OLE DB Provider for ODBC Drivers
Source: TSDBLog
Error Code:
-2147467259; User-defined error code.
Possible System Error: Unspecified error
Step 'Log Results to Database' of sequence 'Log To Database' in 'Database.seq'
Please Help I can't find any solution to this question.
Thank you very much for any help
(3,802 Views)
Accepted by topic author JDASM
Once again, Expression Strings, has stumbled another programmer!
Parameters.DatabaseOptions.ConnectionString is not a string but an Expression String, and your assignment of a StationGlobals.Database ( just a string ) is causing this error.
Here is what I did to solve your issue:
1.) StationGlobals ( remove the leading "\" and trailing \"" from the Database string ) it should contain NO leading or trailing quotes
StationGlobals.Database = Provider=Microsoft.Jet.OLEDB.4.0;Persist Security Info=False;Data Source=C:\\Users\\Public\\Documents\\National Instruments\\TestStand 4.2.1\\Components\\Models\\TestStand Results.mdb.
2.) In Database Options Callback use the following expression to set the Data Source
Parameters.DatabaseOptions.ConnectionString= "StationGlobals.Database"
There are other alternatives as documented in this link.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YILKCA4&l=en-US
Good luck,
PH
(3,792 Views)
Thank you so much that was very helpful
It worked perfectly
(3,786 Views)
