NI TestStand
Passing the UUT serial number from TestStand to LabVIEW
Hello. I'm really new at using TestStand and I'm trying to pass the UUT serial number to a LabView vi. I tried using Runstate.Root.Locals.UUT.SerialNumber as the value to pass but it didn't work. It seemed not to like UUT. Any suggestion would be helpful. Thanks in advance.
(6,219 Views)
Accepted by topic author LesKing2014
It will show in read and give an evaluation warining but it should work at run time.
(6,208 Views)
Getting the same thing.
(3,979 Views)
I would suggest making a new forum post to help more people see your post.
(3,960 Views)
hi i have probleme in my code too
i want to put the serial number from teststand to stieng in labview.
(3,879 Views)
I used a 2 step process. I'm checking to make sure a serial number is entered (not an empty string) and pass the string to a local variable. I can then pass the local variable to LabVIEW.
(3,869 Views)
