01-17-2018 03:59 AM
I have a question on teststand login screen.
is it mandatory to login in teststand. Can I skip this login steps and use the teststand to run my sequence files? will it cause any issue if I don't login ?
Anand
01-17-2018 08:02 AM
You can disable user management under Configure » Station Options » User Manager
-Trent
01-18-2018 07:29 AM
You can also get TestStand to automatically login Windows Systems User (that is done in the same place as mentioned by Trent)
