NI TestStand
Teststand Login Disable
I have a question on teststand login screen.
is it mandatory to login in teststand. Can I skip this login steps and use the teststand to run my sequence files? will it cause any issue if I don't login ?
Anand
(3,023 Views)
You can disable user management under Configure » Station Options » User Manager
-Trent
https://www.linkedin.com/in/trentweaver
(3,005 Views)
You can also get TestStand to automatically login Windows Systems User (that is done in the same place as mentioned by Trent)
(2,990 Views)
