NI TestStand
Password Protecting Plugin Won't Show In Result Processing Insert New
If I password protect (lock) a result plugin and deploy it.  On the deployed machine it won't show up in the Result Processing>>Insert New... list.  Is this a bug?  How can I deploy plugins that are password protected and allow my end user to add them to the list?
NOTE: I do not want it to be an Add-On.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,656 Views)
Hmm... I think there's something else going on here.
I password protected the NI_SimpleTextReport shipping example plugin and deployed it to a machine with nothing but the full featured OI and runtime engines. I'm not able to view the sequence file, but I can still add it as a result processor. Two thoughts:
  • Is it in the correct directory for the bitness of your deployed OI? %TestStandPublic%\Components\Models\ModelPlugins for a 32-bit process or %TestStandPublic64%.... for 64-bit.
  • Are you sure FileGlobals.ModelPluginComponentDescription.DisplayNameExpression isn't the same as one of the other plugins, causing it to show up twice?
-Trent
https://www.linkedin.com/in/trentweaver
(2,631 Views)
Accepted by ~jiggawax~
What version of TestStand are you using? That scenario did not work until TestStand 2016
(2,626 Views)
I'm using 2014 32-bit.  Glad to hear it is fixed.
jigg
CTA, CLA
testeract.com
(2,608 Views)
