NI TestStand
Placing TS_EngineDisplayOpenFileDialog into detailed mode.
I have an open file dialog created by TS_EngineDisplayOpenFileDialog (). Whenever it comes up I always have to put it into details mode and set the sort order to modification date, with the latest at the top.
What I want to do is to have the software do this for me each time it brings up this dialog. Can anyone help here?
I would also like to be able to specify the size of this dialog.
Hurst
(3,126 Views)
Hi Hurst
Unfortunately, there is not a way to sort files and show details in the file dialog box using the TestStand properties and methods.
However, one possible workaround might be to use a windows function call, assuming one exists. You could call this function programatically from TestStand to automatically sort your dialog box, along with displaying the details.
Russell G.
NI Applications Engineering
(3,101 Views)
