NI TestStand
create a labview test
Hi!
I have an issue. I want to create a new labwiew step with testStand.So I:
*configure adaptaters:in the window I select:labview then configure, in the new window I select development system and allow only new templates and ok.
*insert a numeric limit test step.
*right click the new step and select Specify module.
and here I have an error message:
Unable to launch the labview application activeX automation server
error code -18001,an error occured accessing the labview activeX automation server.
If you know what are my errors tell me please!
thanks
sole
(2,998 Views)
Try this.
If that doesn't work, what versions of LabVIEW and TestStand are you using?
Allen P.
NI
(2,971 Views)
