NI TestStand
Possible to customize the type NI_LimitMeasurement?
Is it possible to customize the NI_LimitMeasurement type?
I would like to have a unique measurement ID and measurement name field. For that matter, I would like an ID properter or field for all measurements or test steps. This ID is used to correlate a measurement or test with the testing requirements documentation for a given part to be tested.
(3,370 Views)
What I would recomend is that you make your own NumericLimitTest. Click on the Types button and select MyTypes.in (or whatever ini file you have for custom steps. Insert a new step type and then select Combine With Step Type>Tests>Numeric Limit Test. On this new step, you can then add new fields to the result container or any other place you want. Name the step to something like 'Custom_NumericLimitTest'.
(3,364 Views)
Hi Dennis,
and how to extend this settings table with a new variable? I could't figure it out, even if I create my own custom step type derived from the NumericLimitsTest
(3,037 Views)
I believe that tab is defined by a DLL.
Also, FYI, you're replying to a post that's 4 years old
Humphrey H.
(3,023 Views)
