07-18-2013 06:32 AM
How do I create a customized Numeric Limit Test type, where I can add a new tab (or a variable for example to the Limits tab) to the step settings?
So I need a fifth tab right next to the "Data Source" tab. Is it possible?
07-19-2013 04:20 AM
If you want to add functionality to or customize all instances of a particular step type, you can create a custom step type.
07-19-2013 04:25 AM
In TestStand, you can create custom step types as well as copy and edit existing step types
07-19-2013 04:29 AM
Yes, I can create my custom step types, and I can create edit substep for it. But in that case I see only an additional tab on the step settings, where I see a button. By clicking this button the code module of the edit substep will be called.
That is not the same as what I want. I want to edit the variables directly in TestStand, just like in case of the numeric limit test.
Madottati
07-19-2013 04:40 AM
Do you want to edit the variables directly in TestStand, which variables do you mean?
Do you mean edit LOW HIGH Limit from the Edit Substep ?
Could you provide us more information?
07-19-2013 04:51 AM
On the screenshot you see the step settings for the numeric limit test step type. There are 4 tabs. I would like to have a fifth tab with my variables, where I can edit the values of the variables of my custom step type. Those variables will be used by the code module in run time.
07-19-2013 05:29 AM
This is sounding like you should use a preexpression.
07-19-2013 08:31 AM
It sounds you are looking for a built-in step type.
Please visit this idea
... and if i am right, just give a kudo to this idea...
Regards
Juergen
07-22-2013 01:09 AM
Yes Jürgen, that is what I was looking for.
You have got my Kudo for it.
