NI TestStand
Post Actions: Called Sequence not reporting
I am using TestStand 2.0. I have a step (that is forced to fail) that has the "Post Actions" set to "On Fail:" "Call Sequence". Unfortunately the steps in the called sequence are not showing up in the test report. I can verify that the called sequence is running by stepping through the steps. Also if I call the called sequence from a "SequenceCall" step then its steps do show up in the report. How do I get the steps of a sequence that is called via "'Post Actions' set to 'On Fail:' 'Call Sequence'" to show up in the test report?
(3,500 Views)
Kevin -
You are correct, in TestStand 2.x and 3.0, post-UUT report generation does not display Post Action sequence calls in the report. I think the only-the-fly reporting for TestStand 3.0 does display them. The changes to fix this are fairly small in both the sequence version of the report and the DLL version of the report. The next version of TestStand after 3.0 will probably be adding this in.
Are you using the DLL or sequence report generation code?
Scott Richardson
Scott Richardson
https://testeract.com
(3,500 Views)
(3,500 Views)
Kevin -
Are you using Text or HTML?
Scott Richardson
(3,500 Views)
text
(3,500 Views)
Kevin -
See attached sequences with appropriate changes to include PostAction for the TestStand 2.0 sequences. You should be able to diff these with the original 2.0 sequences to see the changes.
Scott Richardson (NI)
Scott Richardson
(3,500 Views)
