NI TestStand
Safety switch / Parallel Execution
How do I terminate execution of safety.seq (attached) when Safety.vi (attached) output is true?
Also how do I implement this in multiples sequences?
(3,184 Views)
You could attach the output of Safety VI to a variable. Create post and pre step callbacks with the sequence file that check the new variable. when variable set true the terminate all is sent.
I have attach an example.
The sequence file does a random number test in a loop 10 times.
Abort Button VI displays a button thats sets a fileglobal variable. when this is set the test aborts
Random Number Test VI is just a random number numeric test.
Hope this helps
(3,184 Views)
