NI TestStand
PreStep and SequenceCall
the described solution could be a workaround if there would be only one file to provide, but in my case
there should be a lot of files, because my expression is greated with two variables. One is set via an edit step
(specifies the filename) and the user one (specifies the directory)  is set via PreStep execution of  the Sequence Call.
I think it would be a nice feature of TS if only the SequenceFile to be executed should be on place and no
placeholders, even if they could be empty files!
Sunny
Message 11 of 12
(982 Views)
Hi Sunny,
One way would be to use the find file, see example attached.
There is an expression step that perform the action,
Locals.FileFound = FindFile(Locals.FileToFind,True,Locals.Filename), Locals.Filename = Left(Locals.Filename, Len(Locals.FileName)-Len(Locals.FileToFind))
If the file has been found the boolean Locals.FileFound is set True.
Anyway try this.
Regards
Ray (dont know why my text has turn blue) Farmer
Regards
Ray Farmer
Message 12 of 12
(971 Views)
