NI TestStand
Prebatch callback override
In TS 4.1using  the batch process model - PreBatch has two steps
1. Tell Dialog To Get Next UUTs
2. Wait for Dialog.
I need to modify the step #1 but still want to use the exsisting step#2 - Wait for Dialog subsequence.
How to call Wait for Dialog subsequence step when PreBatch callback is overriden in client file?
Thanks.
CLD
(3,943 Views)
The easy answer is to simply copy step #2 from the model to your callback.  Should work just fine.  Everything you need will be passed to you as a parameter.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,940 Views)
Step #2 in the model calls ProcessDialogRequests subsequence. When I copy the step from model to the callback do I not need to copy all teh required subsequence calls like ProcessDialogRequests (and then there are other subsequences also)?
CLD
(3,920 Views)
Also noticed that if I do copy all the required subsequence calls from model to callback then the Fileglobals start giving errors like 'FileGlobals.TestSocketExecutions'.
CLD
(3,918 Views)
Accepted by lvrat
Instead of Use Current File just point it to the BatchModel.seq.  Will that work.  I haven't tested it but I assume it would.
jigg
CTA, CLA
testeract.com
(3,913 Views)
