NI TestStand
Preset instrument only first time on parallel test
One more note:  The batch synchronization steps and step settings will ONLY work with the Batch Model.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
Message 11 of 13
(814 Views)
Hi jigg, thanks for the explanation but I have a different problem.
I have a customize parallel model and I can not change it. I have to find a solution with this "model" without changing it.
If what I have written above is the only way to do that then it's fine.
Message 12 of 13
(814 Views)
Accepted by topic author TomDev
Sorry it wasn't clear to me that you were required to use that model.  I am attaching an example that forces your client file to act like it is in the batch model, even though it is using the parallel model.
Notice that in ProcessSetup I am creating a Batch and then in the Setup group in MainSequence I am adding the thread to the Batch.  Now I can use batch synchronization.
Hope this helps,
jigg
CTA, CLA
testeract.com
Message 13 of 13
(808 Views)
