NI TestStand
Problem with TS 3.0 and sql database
I have a TS 3.0 system that stores the test data to sql database. Since a few days it doesen`t work. When teststand want to store the data the message (attached to this) pops up.
Any ideas?
greetings schwede
Smiley Happy
(3,941 Views)
Hi Schwede,
Questions:
1) If you turn off On-The-Fly logging, do results log properly?
2) Can you post your TestStandDatabaseOptions.ini in the TestStand config directory.
Marco B. NIG
(3,895 Views)
(3,881 Views)
i have made a new connection via odbc sql-server. I mark "save long querys" and watch the log file after the timeout occured. It says: select * from "maintable", but my maintable is too big! Why teststand select all data from the maintable to make a connection? Can i turn it off?
thanks schwede
(3,875 Views)
Accepted by Schwede
the solution ist to use: select TOP 0 * ...  then the table will be loaded empty.
greetings schwede
(3,611 Views)
