NI TestStand
Problem with calling Inoke node (ApplicationManager.Start) working with TS 3.1
I'm developing an User Interface application (LV 8.2) for my two tests.
First test sequence is written in TS 4.0 and LV 8.2; My UI works fine with it.
Second test sequence is written in TS 3.1 and LV7.1 and I have strange behaviour when I launch that seqiuence thru my UI. There is no error but after calling IApplicationMgr invoke node (File1.jpg) with method Start I have no error (error cluster is OK) from it, but a strange message appears and stops application from executing. See File2.jpg. When I click OK everything goes OK.
Any suggestions how can I repair it?
(4,001 Views)
Thats a very unusal issue indeed, I've had a look to see if there are any known issues and haven't found any. Would it be possible for you to post the code in both situations along with the patch versions of your TestStand (via Help > About).
All the best,
(3,932 Views)
Hi Rob,
Here you are my source code distribution.
Summarising, It works with TS engines in versions 3.5 and 4.0 but not in version 3.1
K.
(3,910 Views)
