NI TestStand
how to pass value for value field of return parameters for an action step in teststand sequence file programatically using c#
I used a method LoadPrototypeFromMetaDataToken(token,options) to load the return type parameters. I am unable to set the value field in the return parameters for an action step in teststand sequence file programatically using C#.How can I do that.
(3,267 Views)
