NI TestStand
Programmatic Selection of " Run on Remote Computer "
Thanks Jervin
It works well. I think your valubale information will be very helpful to most of Teststand developers.
With Regards,
Gopal
Message 11 of 17
(2,293 Views)
Hello Friends,
In the sequence editor , i am able to get the TestStand API  RunState.Step.Module.AsLabVIEWModule.RemoteHost = ""
But i am not able to get the same Teststand API properties in Labview with sequence Context. Herewith in attached the image for your ref.
Anyone knows how i can get the above teststand API in LABVIEW.
Prithivi
Message 12 of 17
(2,236 Views)
Hi Prithvi,
Basically what you would have to do is convert the Module ActiveX object reference to the adapter (LabVIEW) specific module class, LabVIEWModule (from the NI TestStand API). You can do this by using the Variant To Data VI in LabVIEW, and wiring in a LabVIEWModule for the type input.
Also, if you look at the auto-generated code for a LabVIEW module, you will notice the following comment under the Sequence Context input:
Refer to the "Using the TestStand ActiveX API in
Different Programming Languages" topic in the
TestStand ActiveX API Reference online help for
information on how to use this reference to access
TestStand properties and variables from your test VI.
This document will be really useful to you and will help you better understand you to interface between LabVIEW and TestStand and I recommend that you take a look at it. You can find it here:
Product Manuals: Using LabVIEW with TestStand
Specifically look at Appendix C: Using the TestStand ActiveX APIs in LabVIEW
I've also attached a sample VI that shows you how to do this.
Jervin Justin
NI TestStand Product Manager
Message 13 of 17
(2,219 Views)
Thanks a lot Jervin.
But one small change requred in the sample code that you have send. We should not open the LABVIEW Moudle with the automation open. It is giving error. Instead of that we can directly connect the Labview Module ref which works without error.
Herewith i attached the img for your ref.
Message 14 of 17
(2,201 Views)
Ouch.
Yeah, I use the automation open to quickly get to the ActiveX server selection dialog and then remove it when I'm done, and totally forgot to do that.
Thanks for the catch!
Jervin Justin
Message 15 of 17
(2,195 Views)
One last point...
The Using the TestStand ActiveX APIs in LabVIEW reference mentions:
When a method or property returns an ActiveX reference, you must release it using the Automation Close function in LabVIEW.
So you'd want to close the reference to Step.Module after your Variant To Data vi since the vi actually outputs a separate reference.
(See attached screenshot)
Message Edited by Jervin_J on 06-06-2008 12:07 PM
Jervin Justin
Message 16 of 17
(2,184 Views)
Thanks Jervin
Really it is a useful information for all the teststand developers
Message 17 of 17
(2,164 Views)
