NI TestStand
Programmatically Change a Property Node Link to Object
Is there a way to programmatically change a "link" to an object in a property node?  I'm trying to create a user configurable front panel for a project that I'm working on, in which the user can change the caption for numerous controls and indicators.  I would like to set-up a for loop that will take information contained in a string array and change each caption accordingly, instead of having 100 different property nodes on the block diagram.  If you need anymore details, let me know and I'll attach a picture in the response.
(3,491 Views)
You mean like this?
The only problem is you must have references to all the objects.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,483 Views)
One more thing is that you might get better help on the LabVIEW forums for this.  I'm assuming you are using LabVIEW.
jigg
CTA, CLA
testeract.com
(3,481 Views)
Yes, I noticed that I was in the wrong forum.  I ended up posting in the LabVIEW forum right after I sent the first message.
I can't open your link since I'm using 8.2 instead of 8.5.  Can you send this in the older version?  I'd be interested in seeing your example.
Thanks!
(3,474 Views)
try this one and let me know
jigg
CTA, CLA
testeract.com
(3,471 Views)
This one might be better for you?
Message Edited by ~jiggawax~ on 01-31-2008 02:02 PM
jigg
CTA, CLA
testeract.com
(3,466 Views)
