Programmatically Set Sequence File Save Indicator in TestStand 2021
I am wondering if there is a way to programmatically set the save indicator status of a sequence file that was modified via a custom step.
In TestStand, when you modify an existing sequence file, an indicator appears on the tab (after the file name) until you save the file.
I've created a custom step that works like this:
1. Drag and drop the custom step from the Insertion Palette to the sequence window
2. A custom form pops up that allows you to enter some data:
3.When you press the OK button, the form is closed and the data is saved to a step property:
4. At this point, the save indicator appears because the sequence file changed (by simply adding the step to the designer):
5. Save the sequence file; the save indicator goes away:
6. Edit the step by pressing the Edit button in the Step Settings panel to open the form:
7. Change the data:
8. When you press the OK button, the form is closed and the new data is saved to a step property:
9. At this point, the save indicator is absent.  Even though the step data changed, I still want the save indicator to display:
This is the C# code that is used to save the data to the step variable: 
stepAsPropObject.SetValString(lookupString, PropertyOptions.PropOption_CaseInsensitive, value);
* stepAsPropObject is an object of type NationalInstruments.TestStand.Interop.API.Step that is passed to the method as a NationalInstruments.TestStand.Interop.API.PropertyObject:
I've not found anything in the documentation that indicates this can even be done.  Maybe I missed it.  So can anyone please help me determine if this can be done and how?
Scott
(1,940 Views)
Accepted by ScottTE
Try PropertyObjectFile.IncChangeCount or SequenceFile.IncChangeCount.
(1,928 Views)
That did it.  Thanks for the help!
(1,901 Views)
