Programmatically disable result recording for skipped Steps or sequence calls
hii,
I want to  disable result recording for steps that are skipped (due to Precondition selection) .
I tried in SequenceFilePostResultListEntry callback  but did not find any elegant solution. I want to avoid using "SequenceFilePostStep"  callback.
any easy ideas  to implement the same.
regards,
Akshay Parab
(4,581 Views)
Accepted by aparab
Hi Akshay,
I think you were on the right path with using the SequenceFilePostResultListEntry callback; I would use that callback with the following Statement Step:
Pre-Condition:
Parameters.Step.Result.Status == "Skipped"
Post-Expression:
Parameters.DiscardResult = True
I've attached an example.
I hope this helps,
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(4,569 Views)
thanks
(4,546 Views)
Thanks for pointing out!
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(4,538 Views)
No problem Smiley Very Happy
(4,536 Views)
