Programmatically insert folder into Templates>Steps
I am creating a dynamic step template creator sequence. The steps are split saved in different folders under. Templates>Steps. I want the create the subfolders programmatically so the folder do not have to be created before hand,  Is there a way to programmatically insert a subfolder into the Templates>Steps (see image attached)?
(2,455 Views)
In the Watch View we can see that it is an Array of Containers.
However, when I tried to add an Array of Containers it was not shown as a folder but as... an Array of Containers... I don't see any special attributes nor properties to mark it as a folder...
The workaround could be to clone one of the folders that are already in the templates list or import some dummy folder from a file and adjust to what you need.
Can you show the approach u used to insert templates?
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(2,367 Views)
Accepted by RktScientist97
Ok I figured it out. It is a comment 😄
You need to create an Array of Containers (in example Locals.Folder) and comment it with NI_TEMPLATE_CATEGORY.
Then simply use this:
RunState.Engine.GetTemplatesFile(0).Data.Root += {Locals.Folder},
RunState.Engine.GetTemplatesFile(0).IncChangeCount(),
RunState.Thread.PostUIMessageEx(UIMsg_RefreshWindows, 0, "", Nothing, True)
Michał Bieńkowski
CLA, CTA, CPI
(2,364 Views)
Thank you so much. This works like a charm! I had given up on this like a month an a half ago 😂
(2,354 Views)
It was difficult because it's counterintuitive. I was looking for attributes.
I ended up scanning all the properties 😄
Michał Bieńkowski
CLA, CTA, CPI
(2,344 Views)
I realized that if you use RunState.Engine.GetTemplatesFile(0).Data.Root += {Locals.Folder} to insert an item, Templates are kind of frozen until you restart TS. To fix it, use the Clone() method as below:
Locals.TemplatesFile.AsPropertyObjectFile.Data.Root.SetPropertyObjectByOffset(GetNumElements(Locals.TemplatesFile.AsPropertyObjectFile.Data.Root), PropOption_InsertElement, Locals.FolderPlaceholder.Clone("", PropOption_NoOptions))
Michał Bieńkowski
CLA, CTA, CPI
(2,269 Views)
