NI TestStand
Programmatically launch user manager?
Is it possible?  I don't see a command type or an API for it.
(4,957 Views)
Hi jsiegel,
It depends on what you want to do with the user manager. There are a number of API calls that will allow you to create and manage users. Take a look at some of the following documentation:
http://digital.ni.com/public.nsf/allkb/563B5DDFA5014A0886256F880018D1FB?OpenDocument
http://www.ni.com/pdf/manuals/372844b.pdf
Kristen M
Automated Test Product Marketing Engineer
(4,934 Views)
I think the user manager is built into the sequence editor and cannot be detached.  I'm sure it is just calling into the API.
http://digital.ni.com/public.nsf/allkb/8DFDCC6D8C0DEFB08625799F0074B616
That link should get you on the right track.  Forgive me if it is the same one Kristen showed.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,931 Views)
I know I can use the API to recreate my own user manager (to add/edit/delete users), but I would rather use the entire user manager UI that is already complete and working!  But I think jigg confirmed my suspicions that this is not possible.  I guess I have to go reinvent the wheel!  Thanks.
Jeff
(4,927 Views)
Hi Jeff,
How is reinventing the wheel going? Could you share some code?
BTW I think that NI should support creation of custom User Manager because it is pointless to deploy custom UI without possibility to manage users in it...
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(3,452 Views)
Michał,
Sorry, I did not create my own custom user manager because the feature was not important enough to spend time on.
(3,315 Views)
