NI TestStand
Use the SearchandReplace function to insert a specific date and time format as the replacement string
LabVIEW allows you to specify the format by using format codes for example
MMDDYY-00:00 would be specified like  %m%d%%y-%H:%M
I’m looking for an equivalent way to specify this in TestStand that I can use the SearchandReplace function to replace text in a template file with the format specified by the LabVIEW statement above.
(3,826 Views)
Hi RF_Dude_22,
Formatting date and time in TestStand is more manual than it is in LabVIEW. This example shows how you can generate a date string using the Date() function. The same idea can be applied using the Time() function to create a time string.
Steven Gloor
Staff Customer Engineer - CTA, CLD
(3,774 Views)
What I have done is created a vi that creates the string I need in the format I need and assign it to a Local in TestStand, then I just read the contents of that Local using the SearchandReplace function. This works well, but was really hoping to be able to have TestStand creat the format I need, but have been unable to find a way. Yes, I can use the Date() and Time() functions to get the information I need, but then I still need to parse out the information I need, similar to the example you have pointed me at.
(3,768 Views)
As Steven stated, you can use the Time() and Date() functions and format the returned values into the desired format using the following expression:
Locals.Date = Date(False,Locals.Year,Locals.Month,Locals.Day),
Locals.Time = Time(True,Locals.Hour,Locals.Minute,Locals.Second),
Locals.FormattedDateTime = Str(Locals.Month, "%02s") + Str(Locals.Day, "%02s") + Right(Str(Locals.Year),2) + "-" + Str(Locals.Hour, "%02s") + ":" + Str(Locals.Minute, "%02s")
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(3,639 Views)
