NI TestStand
Programmatically launching development OI
Is there a way to programmatically launch the standard development OI (as if I had double clicked the TestStand icon on the desktop)?  I could of course do this with a system execute call, but I'm curious if it is doable from an actual TS API call.
(3,975 Views)
Accepted by BowenM
There is not an API call for this.  Your best bet is to call it from the command line as you suggested.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,969 Views)
Thanks.  My googling / research indicated that was the case, but I wanted to verify.
(3,966 Views)
