NI TestStand
Programmatically loading and executing a sequence file in LabVIEW
Does anyone have any LabVIEW code that programmatically loads and executes a sequence file and then returns the end results?  Is it best to do this using the LabVIEW TestStand UI controls or using direct calls to the TestStand API?
(4,940 Views)
Ryan,
i asume that you are going to implement an Operator Interface on your own. I hope that you will start off one of the example OIs supplied with TS.
There you are communicating with TS via ManagerControls. One manager control, the Application Manager, includes a method called "OpenSequenceFile. This would be the one you are looking for if you want to load a sequencefile.
If you want to execute the sequence, you should look into the NewExecution Method from the TS-Engine-Class.
hope this helps,
Norbert B.
Norbert
Expert: Geometry
(4,923 Views)
Ryan,
I've had a good example from Andy McRorie, see this (example2.vi).
Hope this will help
Bye
JLM
(4,918 Views)
Thanks Norbert and Jose for the help.
(4,901 Views)
