NI TestStand
c# program needs to login automatically and run a sequnce file!
I am trying write a program that launches the c# testexec.exe user interface with command line parameters like this: 'testexec /run MainSequence "{sequence path\filename}" /quit'.  I don't want to use the windows user name that is logged on to windows as the automatic logon because I would need to maintain each user inside teststand.  Is there someway I can modify testexec.exe to pass the user name and password and avoid the logon dialog box?
(3,968 Views)
Hey Terry,
What you are wanting to do is possible with the following method:
  • You can automatically log the user in by setting the Engine.CurrentUser equal to some user (by using Engine.GetUser(string user name)).
  • Configure two properties for the Application Manager: LoginOnStart = false, ProcessCommandLine = true.
  • After the application manager start method, add a call to ApplicationManager.Login().
  • In the FrontEndCallbacks sequence, add a condition for the Login step that checks if Engine.CurrentUser == Nothing.  That is, if a user is already logged in, do not prompt the user with a dialog.
These settings combined with the property ApplicationManager.CommandLineArguments (providing you with the user name and password to use) should yield you a solution.
Andy McRorie
NI R&D
(3,945 Views)
