NI TestStand
Programmatically loop through multiple measurement limit tests
Hi all,
Its pretty common for me to have to check multiple voltages on a device in manufacturing.
I'm looking for a way to create a generic sequence, that I feed a file to that, governs how many times to loop though a voltage measurement subVI.
I'd like to pass an array like this via a file.
Testname  |  Voltage Limit High | Voltage Limit Low
Item 1       |    3.2                     I      3.4
Item 2       |    4.8                     |      5.2
Which would cause the VoltageRead.VI sequence (Theoretical VI) to loop 2 times and report a voltage each time which gets evaluated against the upper and lower limits.
I can do it in labview with teststand passing the file name to a DynamicLoopVoltageRead.VI and spit out a boolean array of pass/fail but I would like to know if there is a more elegant method in test stand.
Any help is greatly appreciated.
_Chris
(4,637 Views)
Accepted by chrisludes
Chris,
Does your file have to be formatted exactly like that?  If so then you will need ot a create a VI to read in the file and call it separately as an action step.  If not you can use a property object file and just use the built in TestStand functions.
Attached is a sequence that shows how to loop on a step.  Yours would of course be a VI call and not the none adapter.
BTW- your low limit is higher than your high limit... 🙂
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,630 Views)
Thanks that works.
The formatting isnt important and ill stick with what teststand loves the most.
my low limit moved to colorado.
_Chris
(4,299 Views)
