NI TestStand
Programmatically set limits of a test step
I am rather new to TestStand and was wondering how can I programmatically set limits based on the value of a global variable?
(3,552 Views)
Quintin,
You can use the property loader step type to load your limit values from a source file or database.
If you want to set them based on a global variable you can use a pre-expression.
Right Click on your step...
Go to Properties...->Expressions->PreExpression
Add a expression to set your step limits. For example for a numeric Limit Test Step you could add the following pre-expression:
Step.Limits.Low = StationGlobals.Global1,Step.Limits.High = StationGlobals.Global2
Pre-Expression is evaluated before the module is executed.
If you want to learn more about the 'order of actions that a step performs' you can go to the Step Execution Section in Reference Manual Chapter 3.
Hope it Helps.
Antonio Lie.
(3,537 Views)
Thanks Antonio,
I ended up using expession statesments inside IF, ELSE flow control steps, if that doesn't work I will rework to use your method.
Quintin
(3,519 Views)
