NI TestStand
add more results to report
How do you add additional test results to a report?  I am performing a bit error rate test and would like to add in # of failed 1s, # of failed 0s, # of fails, aside from the actual bit error rate?
Brian
(3,382 Views)
There are a lot of ways, but one of the easiest is to add a NumericLimitTest step for each value using the <None> adapter.  Set the Data Source Expression to be the value to log and set the Comparison Type to <No Comparison>.
(3,378 Views)
You could also do the same thing with a single Multiple Numeric Limit Test step instead of separate Numeric Limit Test steps.
(3,377 Views)
Good idea, thanks.
(3,367 Views)
