NI TestStand
Programmatically set tracing options
Hi all,
in my custom operator interface i succeded to enable or disable tracing via API.
What i want to do now is to set (again via API) every single options shown in the "Configure -> Station Options -> Execution -> Enable Tracing" TestStand window, such as "Allow tracing into setup/cleanup" or "Allow tracing while terminating".
How can i realize this?
(4,983 Views)
Have you seen this thread?
hope this helps,
Norbert
Norbert
Expert: Geometry
(4,979 Views)
Hi Norbert,
that thread explain how to enable or disable tracing. I already succeded doing this.
What i need to do in this moment is to enable or disable tracing options.
(4,976 Views)
Accepted by aRCo
I think you are looking for the ExecutionMask....
Norbert
Norbert
Expert: Geometry
(4,974 Views)
ExecutionMask: the perfect suggestion!!!! Smiley Happy
(4,970 Views)
