07-20-2005 08:24 AM
Currently, I am using the XML Reporting format with the StyleSheet set to expand.xsl. This format is great for our report generation needs except for one small thing. When the xml report is opened, all the fails are expanded by default. What we want is that all the step results should be collapsed when the document is opened. I tried looking around in the report options to see if there is something I can do, but could not find anything. It looks like the source code for expand.xsl will need modification in order for this to happen. Do you have any suggestions/comments?
Any help will be much appreciated.
Anuj Gupta
07-21-2005 11:49 AM
07-21-2005 01:46 PM
07-22-2005 11:16 AM
07-22-2005 11:49 AM
07-25-2005 10:41 AM - edited 07-25-2005 10:41 AM
Message Edited by Tyler T. on 07-25-2005 10:42 AM
07-26-2005 09:06 AM
I found out that the modified stylesheet was being pulled out from a different location and not the folder it should have been in. I was sure I had put it in the right spot, but I was wrong.
It works perfect now. Thanks for the help and I apologize for the inconvenience caused to you due to my negligence.
Thanks again
Anuj
06-05-2009
11:03 AM
- last edited on
11-05-2024
03:20 PM
by
Content Cleaner
Just an FYI for completeness, TestStand 4.2 features improved XML Style Sheets that are restructured to reduce the time required to generate HTML output from XML report files and to simplify the task of modifying style sheets so that you can change the appearance and content of XML reports.
For more information about customizing TestStand XML report style sheets and using the included XML schemas, refer to:
NI TestStand Help: XML Report Style Sheets
