NI TestStand
Queue with computer-based name not found
Workaround 1) is perfectly OK, thank you.
We are using these queues in an environment where we distribute work to threads on one machine and remote engines on other machines. I did not anticipate a need to dequeue from both types simultaneously.and had originally chosen the scheme to use local names where possible, computer-based names only where necessary, because local queues are slightly faster (the asterisk-queues being considerably slower, I noticed).
However, the absolute difference in turnaround time is so small that it is absolutely OK for us to use fully qualified names everywhere.
thanks
Peter
Message 11 of 12
(795 Views)
Nice idea, using the process ID in the queue name.
Peter
Message 12 of 12
(795 Views)
