Read command line arguments with an ActiveX step
Hi
I would like to read the command line parameters from TestStand startup. I did find an ActiveX resulting in a Object Reference (See Locals.CommandsRef). How do I use this reference to really get the arguments and their count? See also screenshot.
(3,976 Views)
Hello Paulus,
It's possible to access command line arguments in the following (pseudo-code) way:
Locals.AppMgrRef = RunState.Engine.GetInternalOption(InternalOption_ApplicationManager);
Locals.CommandsRef = Locals.AppMgrRef.CommandLineArguments;
Locals.CountNum = Locals.CommandRef.Count;
For i=0 to Locals.CountNum - 1
    Locals.CommandString = Locals.CommandRef.Item(i);
End
Do you want to use it with the actual TestStand Startup or rather with the start-up of a sequence file?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(3,931 Views)
Hoi Thierry,
Thanks for the help. To start with the easyiest part: I would like to know the arguments of the starting sequence file.
Ik saw this pseudocode before but don't know what to do with it. I would like to read the arguments in TestStand. Where do I put this pseudocode? It makes no sense putting it in a TS-statement.
I tried to use ActiveX as seen in the sscreenshot. Is that a wrong direction? If correct, how should I go on with this Object reference.
(3,928 Views)
Accepted by Paulus56
Hi Paulus,
Via this link, you find an forumthread that describes the same issue. testStand does not support this, but there is a workaround. Attached you find the code.
The attachment includes a LV vi with the command line. If you doen't use Labview, here is the command line:
C:\Program Files (x86)\National Instruments\TestStand 2012\Bin\SeqEdit.exe /goto "Parameter1 = test" /runEntryPoint "Test UUTs" D:\Testsequence.seq
Bas
(3,887 Views)
Thanks for the solution. This works.
(3,880 Views)
Hello Bas,
Thanks for helping during my absence (giving courses)!
I'll give you a kudo too.. 😉
Kind Regards,
(3,870 Views)
