NI TestStand
Read station global variable from teststand simple user interface code.
How to read a station global variable from testsstand simple user interface code.
sample code would help.
Anand.
(3,604 Views)
Accepted by AnandR
Assume you have a global named StationGlobals.Foo that is of type string.
ApplicationManager.GetEngine.Globals.GetValSring("Foo", 0).
Attached is an image in LabVIEW.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,589 Views)
Hi Jigg,
Thanks, I want to read station global variable after some specific steps run in my application sequence file. May I know which part of the state machine in simple user interface block diagram I need to include the code(you suggested).
The simple user interface has below states.
Initialize
Configure Connections
Register Event Callbacks
Start Application
Handle Events
Shutdown
Handle Errors
Anand
(3,544 Views)
