‎06-26-2020 09:02 AM
Hello Community,
I am new to using Teststand and am looking for a way to read the Network variable value that i have created and published through labview. I can see my CVI code alter the NV values in the NI Distributed systems but I need to read the NV values through a teststand sequence.
Can someone point me to some resources to do this.
Thank you,
Kaizen
‎07-01-2020 06:54 PM
If it were me I would call the VI that is able to read it.
‎07-07-2020 08:29 AM
Hi jigg,
Thank you for your response.
I have the Network Variables called out on a LabVIEW .lib file. Do you mean that I call the LabVIEW utility feature in test stand and Deploy library to read/write the status of Network Variable ?
Kaizen14
‎07-07-2020 05:31 PM
Yes
