NI TestStand
Reading Network Variable value in Teststand sequence
Hello Community,
I am new to using Teststand and am looking for a way to read the Network variable value that i have created and published through labview. I can see my CVI code alter the NV values in the NI Distributed systems but I need to read the NV values through a teststand sequence.
Can someone point me to some resources to do this.
Thank you,
Kaizen
(2,869 Views)
If it were me I would call the VI that is able to read it.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,818 Views)
Hi jigg,
Thank you for your response.
I have the Network Variables called out on a LabVIEW .lib file. Do you mean that I call the LabVIEW utility feature in test stand and Deploy library to read/write the status of Network Variable ?
Kaizen14
(2,801 Views)
Yes
jigg
CTA, CLA
testeract.com
(2,785 Views)
