NI TestStand
Reading Qorivva MPC5604P microcontroller register values using Teststand
Is it possible to Read the Qorivva MPC5604P microcontroller register values using the Teststand?
Please suggest.
SK
(2,281 Views)
Technically you would need a code module to do the actual reading.  TestStand is a test executive and a scripting language that calls code modules.  Code modules can be written in LabVIEW, .NET, ActiveX, C, C++, etc...  So if one of those languages can do it then TestStand can call it.
In addition to any command line calls, adapters are what interface to the different languages.  Here is more about them: https://www.ni.com/docs/en-US/bundle/teststand/page/module-adapters.html
Cheers,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,279 Views)
Thanks for your inputs.
SK
(2,261 Views)
