NI TestStand
Reading Sequence file of NI teststand in c#
Hello all,
I want to read a sequence file (alredy generated) using c#. Also i want to edit sequence file using c# only. How can i acheive this? Can anyone guide me?
thanks
(2,753 Views)
This depends on the file type you selected when generating the sequence file. Default configuration is "binary" and NI does not disclose how data is stored in there.
However, you can change file type to ini or XML. There is no public documentation on how these files are built up, but with a little investigation i am pretty sure that you can understand the sections/keys (ini) or tags (xml).
Norbert
Expert: Geometry
(2,714 Views)
