NI TestStand
TestStand dictionaries guide
I need to localize my custom Operator Interface. What is the best way to link particular item, that needs to be transleted in oryginal english dictionary, with apropriate ini file and category/symbol? Is there any guide to this dictionaries?
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(3,308 Views)
Michal -
The category and tag values in the language INI files are defined in the source code for TestStand applications. For more on the format of the INI file, see the "Creating String Resource Files" help topic. If you have access to the source code like the example User Interfaces, they will typically use the functions as outlined in the "Localizing User Interfaces" help topic.
For applications that you do not have source, you will not have access to the category and tag names used by each control or non-control string. Your only option is to search the English string for a match and go from there. Most of them should be easy to find especially if they are relatively unique.
Scott Richardson
https://testeract.com
(3,257 Views)
