NI TestStand
Reducing TestStand Data Logging to Database Server
Hello All,
I have a quick question regarding TestStand Data logging to database servers. When TestStand executes a step, it by default logs Error Container to the database. I was just wondering can we disable error results logs to database. Error container by default is set as Not Deletable and even when I set Flag not copy to Result, its copied.
I tried following approach but still TS is logging error container to DB. Same is the case with "Commom" property container. What does this property do and how to disable it.
Database look like this,
Any help will be greatly appreciated. I want to reduced data logging to server to save space. Thanks so much in advance.
Kind regards
Message 1 of 1
(1,820 Views)
