NI TestStand
References to PropertyObjects were not released properly.
I am getting the following Error on closing the TESTSTAND.
    Total number of objects: 65570
    Number of top-level objects: 199
    Note: Some top-level objects may be included if they are referenced by
    an incorrectly released top-level object. For example, an unreleased
    SequenceContext object references a SequenceFile object.
    The following top-level objects were not released:
        SequenceContexts [3 object(s) not released]
            SequenceContext #1:
                The context last executed sequence 'Configure UUT Information' in file 'Common_ATE_SequentialModel.seq'.
            SequenceContext #2:
                The context last executed sequence 'PreUUT' in file 'Common_ATE_SequentialModel.seq'.
            SequenceContext #3:
                The context last executed sequence 'Test UUTs' in file 'Common_ATE_SequentialModel.seq'.
        Files [1 object(s) not released]
            SequenceFile #1:
                Path: D:\Honeywell\CommonATE\TED\Framework 3.0\CommonATEModels\Common_ATE_SequentialModel.seq
        Sequences [3 object(s) not released]
            Sequence #1:
                Name: Configure UUT Information
            Sequence #2:
            Sequence #3:
        Type Definitions [47 object(s) not released]
            Type Definition #1:
            Type Definition #2:
            Type Definition #3:
            Type Definition #4:
            Type Definition #5:
            Type Definition #6:
How to release the resources used?
Am using some GUI's created in .Net Internally i doubt it creates the problem?
Help me in identifying this problem
Thanks in advance
Bharathi
(4,173 Views)
Does your GUI open or use any references to your execution? The debug reports show you're not releasing three sequence contexts from your process model.
(4,160 Views)
Most likely it is the GUI that is not releasing things. If any TestStand objects aren't released before the TestStand Engine is destroyed then they are reported as leaks. .NET complicates things because it releases references only when garbage collection occurs. Look at our example C# UI for places in which GC.Collect() is done. Also if you get a sequence file using Engine.GetSequenceFile[Ex](), you need to make sure you release it when you are done with it using Engine.ReleaseSequenceFileEx.
Hope this helps,
-Doug
(4,157 Views)
