NI TestStand
Changing sequence callback programatically
How do I change between two versions of a sequence callback programatically?  For example, if I am debugging, I want to run a different version of SequenceFilePostStepFailure than when I am in production mode.
Or if I modify the SequenceFilePostStepFailure callback in the process model, how do I programatically turn on or off the override callback?
(3,326 Views)
The easiest way (albeit sloppy) I can think of would to include both versions of your callback, but append _Development or _Production to them. In the actual callback, use a sequence call and call the correct one by expression. To track whether or not you're in production mode, you could use a Station Global.
(3,323 Views)
Thanks for the response ... that's pretty much what I've been doing but was hoping there was a slicker way to choosing between sequences.
(3,314 Views)
