NI TestStand
Retrive the names of step measurements using LabVIEW
How do you retrieve the names of a multiple numeric step's measurements using LabVIEW?
I've constructed a vi to call from TestStand, and will pass it "ThisContext", but the vi doesn't complie.  That's how far I got.  The vi is attached.  The error message is:
"The method selected in the invoke node is invalid or no method has been selected.  Right-click the invoke node and select a method."
My vi is an attempt to write the code from message.id=10653 in LabVIEW.  Specifically:
Dim MyStep As [Step]
Dim MyMeasurement As PropertyObject
MyStep = seqContext.AsPropertyObject.GetPropertyObject("Step", 0)
MyMeasurement = MyStep.AsPropertyObject.GetPropertyObject("Result.Measurement[0]", 0)
MsgBox(MyMeasurement.Name)
 Can someone help me finish the vi?
(3,275 Views)
You missed the the AsPropertyObject in "MyMeasurement = MyStep.AsPropertyObject.GetPropertyObject("Result.Measurement[0]", 0)". Checked out the attached.
I cleaned up your code. Make sure you're closing every reference you get from TestStand or it'll yell at you when you shut the engine down.
(3,270 Views)
Accepted by topic author mike_22
Thanks very much.
One small change to the vi required.
(3,265 Views)
