NI TestStand
Retrive the names of step measurements using LabVIEW
How do you retrieve the names of a multiple numeric step's measurements using LabVIEW?
I've constructed a vi to call from TestStand, and will pass it "ThisContext", but the vi doesn't complie.  That's how far I got.  The vi is attached.  The error message is:
"The method selected in the invoke node is invalid or no method has been selected.  Right-click the invoke node and select a method."
My vi is an attempt to write the code from message.id=10653 in LabVIEW.  Specifically:
Dim MyStep As [Step]
Dim MyMeasurement As PropertyObject
MyStep = seqContext.AsPropertyObject.GetPropertyObject("Step", 0)
MyMeasurement = MyStep.AsPropertyObject.GetPropertyObject("Result.Measurement[0]", 0)
MsgBox(MyMeasurement.Name)
 Can someone help me finish the vi?
(3,271 Views)
You missed the the AsPropertyObject in "MyMeasurement = MyStep.AsPropertyObject.GetPropertyObject("Result.Measurement[0]", 0)". Checked out the attached.
I cleaned up your code. Make sure you're closing every reference you get from TestStand or it'll yell at you when you shut the engine down.
(3,266 Views)
Accepted by mike_22
Thanks very much.
One small change to the vi required.
(3,261 Views)
