NI TestStand
Regarding Teststand scripting language
I just want to know, when we are creating the *.seq file, then that sequence file in which scripting language it is created.
(824 Views)
Accepted by awast
There is no Scripting language, you usually use the TestStand API to create sequence files.
Though you can also use XML based .seq files:
https://youtu.be/jEL6c0grEX0?feature=shared
(821 Views)
