NI TestStand
Reloading prototype not working for TestStand 2017
Hi All
I am having a weird observation in TestStand 2017 version.
I am using "Run VI asynchronously" option present in Teststand to call on LabVIEW VI.
I changed one of the connector pane of this VI and tried to reload the same in TestStand.
However whatever I tried , the Updated VI prototype is not getting loaded and its keeps showing me red warning icon.
I have checked following :
1. VI is not broken in LabVIEW development system
2. "Sepearte compiled code from source file" option is unchecked in LabVIEW for this VI
3.In advanced settings of "Run VI asynchronously" step, "Always run VI in LabVIEW Run-Time" is unchecked.
I am not able to figure out this very basic thing.
what could be the reason for this?
(2,580 Views)
Accepted by LV_user1
Is your LabVIEW adapter set to runtime engine or development environment?
Are you using a Project Path? If so get rid of it and point directly to the VI.
Do you have 2 controls/indicators with the same name on your connector pane.  It should still work but I have seen issues with that.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,513 Views)
Yes... first point mentioned by you was the issue.
My adapter settings was not set to LabVIEW development system
I changed it and problem solved.
Thanks for your reply!!!
(2,498 Views)
