RemoteEXEServer.exe Not Working + Exception
Hi Sir Cat Very Happy,
am Trying to run an executable on a remote pc from Teststand. looking around i found a possible/easiest solution is to use that RemoteEXEServer.exe (wich is provided by installing Teststand) & Call Executable Teststep.
I configured every thing similar to AllenP's description
Trying to put a password already throws an exception from HRESULT:0xFFFFBBA4 Error Code: -17500, Operation Failed.Source: NationalInstruments.Teststand.Interop.Api. see "exception_pwd.png" for details.
leaving di password field empty then running the teststep causes a Run-Time Error: -17502; System Level Exception. See second picture "run_time_error.png" for details.
(3,044 Views)
Have you seen these articles surrounding your error codes?
Error -17500 Using The Property Loader From Caller Sequence: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000001DdMLSA0&l=en-GB
TestStand Error -17502 Using Automation Server: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019ToqSAE&l=en-GB
Michael
(2,997 Views)
hi,
yess, these 2 articles were di first thing tried.
have you got it to run? remotely? because locally every thing is ok!
one problem appears  just by typing a password (error -17500 ) and i dont think that i have any influence on that (maybe a bug?).
by the way am using Teststand 2017 SP1 32bit
(2,950 Views)
Have a look over this.
Remote Execution in 32-bit TestStand and 64-bit TestStand: https://www.ni.com/docs/en-US/bundle/teststand/page/remote-execution-in-32-bit-teststand-and-64-b.ht...
It might be to do with the set up
(2,942 Views)
@mdoherty
Sorry u misunderstood, CallSequence on RemotePC has nothing to do with RemoteEXEServer.exe and Call Executable:
CALL Executable Remote ConfCALL Executable Remote ConfRemoteEXEServerRemoteEXEServerSquenceCALLSquenceCALL
(2,908 Views)
did someone ever seen it working? Smiley Sad
(2,890 Views)
